Flexi Hose sizing???
17 Sep 2012
Durham
I am looking at using some flexi pipe to connect a boiling water tap to its hot tank. I need the pipe to be able to withstand temperatures of 110 degrees and pressures up to 6 BAR. Is this possible?
Also. I need one of the pipes to be female (end 1) and female (end 2) what is the smallest size I can get? 10mm? 12mm? Or is there a better size I should be using?
Any help greatly appreciated.
The only type which MIGHT be useable for that application is the convoluted copper flexible pipes.
Alternatively use soft copper 10 mm tube if its not to be regularly moved.
