I own a flat in a fairly new development, and I'm in the process of buying one of the houses. I got someone in to do a safety check on the house prior to exchanging contracts - and it failed. Somehow I don't think the vendor is going to be very happy, I've already made him have the boiler repaired (which also wasn't working today) while he thought he'd just leave it for me to fix.
Anyway, when these properties were built, there is a flue built into the wall using precast blocks. I didn't realise this until I had the electric fire out in the flat to get the model off the back (needed new elements) and happened to look up. Needless to say, at every joint is a big bead of mortar that the bricky couldn't be a**ed to wipe off
In the attic, there is a piece of flexible flue linking a pipe sticking out of the wall to a ridge terminal. For the flat, there are two in the same attic - meaning my flue can't be inspected/worked on without going though the flat above.
I especially like the way one of them is gaffer taped to the timber - so no clearance from combustibles there
And the flue in the house, just like those in the flats
Now I'm told these are not acceptable, hence the gas guy turned off the gas to the fire and put a big red sticker on it. So even if the vendor decides not to sell to me, he'll struggle to have people overlook that now !
I'm also told that this flue would not have been acceptable when the properties were built - I think around 1992 to 95. Is that the case ? If so, then I have to wonder where the building control inspectors were looking when they signed off the properties.
I flick through Part J, I see mention of not passing flues through other properties due to potential access problems. Did this apply back in the 90's as well ?
Oh yes, and just for good measure, the house has a fairly new fire installed - so I guess the installer either didn't look at all, or had his eyes closed when he inspected the flue.
I see this isn't a new or uncommon problem, as I see in threads like this and this and this.
Should I be saying anything to anyone about this - apart from making the house vendor sort it out ? Should I be trying to find out who installed the fire and tell their authorising organisation ? Or is that just wasting my time ?
I'll post another thread about the boiler - a British Gas job, so I imagine there'll be nothing new there either.
