Hi there,
We have already bought our 18mm thick tongue and groove Solid Oak Flooring, that is pre oiled. It's also very heavy and weighs approx 700kg across 50 sq metres.
It is currently being acclimatised for 7 days.
The concrete sub floor has has been self levelled and is mostly very level, expect for minor 1-2mm variations around 2 join areas. The sub floor has also been treated with 2 coats of Sika liquid DPM and there should no moisture coming through at all.
I have already bought 5mm thick Fibre Board underlay, that has good insulation and sound reduction properties and levelling properties to compensate for those minor floor variations.
The manufacturers website and other websites also state that this fibre board CAN be used with Solid Wood Flooring.
So what i want to do is to apply the 5mm fibre board underlay and "Float" the solid oak floor with no glueing and with 12.5mm expansion gaps on all 4 sides. These gaps will also be filled with 12.5mm cork strips. The fibre board is also fairly course and the undersides of the oak flooring are grooved and will dig into the fibre board slightly when you stand on the oak floor.
OR could i float the floor, but Glue all of the tongue and groove sections?
OR is this just a TERRIBLE idea?
The flooring company mention using a Self Adhesive Underlay that sticks to the wood but floats on the sub floor. But this isn't as thick or as insulative as the fibre board or as good for levelling imperfections.
One other idea of mine is to use the 5mm Fibre Board and another seperate adhesive to stick the oak flooring to the fibre board. Providing a similar result to the self adhesive underlay recommended by the flooring company.
Any advice would be greatly appreciated,
