I certainly wouldn't hold that against you since, as we've been seen, many others would probably, and 'in good faith', do the same (despite what the regs might actually say!).So if I done an EICR for you and put a C3 for that floating socket would you use me again?![]()
On the other hand, going back to the recent story I told, if you gave my shower circuit a code of any sort because it was so long that any residual current would have reduced to too little to trip the RCD in the distant CU by the time it go there, then I probably wouldn't be seeing much of you after that!
I have to say that, although we talk quite a lot about EICRs having vey questionable C2s, often possibly in attempts to 'generate ('unnecessary') work', a fairly high proportion of the inspectors we've decided 'never to use again' have been in that position because they have 'missed things', rather than 'made things up'! Off the top of my head, I think I'd say that the things most often missed are probably 'spurs off spurs' - although I have to say that the most recent one we 'showed the door' had failed to comment on, let alone code, a very significant amount of VIR cable that was still in-service ! To restore one's faith in decent tradespeople, we got a second (again, 'new') electrician to look at that installation ('just for the hell of it') - and after just a few minutes looking around told us that there was no point in wasting money on an EICR, since it was obvious that a complete re-wire was needed.
