flooded garage no sign of leak around pipes. Has any pulmber came accross this before?
13 Apr 2011
Antrim
hi my garage has flooded and there is no sign of leaks around pipes what so ever. and no rain in days. has a pulmber ever been called out where someone thought it was pipes but with no leakage to be found ? i am baffled
Are you terraced/semi ?
I got called to a major leak at a terraced house and it was so bad it ran through the party wall...the neighbours had also called out a plumber thinking they had a leak.
semi. although the garage is not connected to next doors garage
Well that rules out a mains/supply pipe as it would just keep flooding again, they don't tend to self repair. Only other thing it could be is a drain/ground water etc
