- Joined
- 3 Nov 2013
- Messages
- 41
- Reaction score
- 0
- Country
Hi All,
I am converting my garage into a living space (permitted development).
The current floor is an un-insulated concrete slab with a 2" slope
My current plan is as follows:
Damp proof membrane directly on the slab.
Then 50mm foil backed Celotex.
Then a screed to level the floor, 1" at thinnest to 3" at thickest point.
Then 1" battens and 1" Celotex
Then floor boards
I understand that regs call for 1200mm of Celotex but their is no way I can raise the floor that much.I have seen multifoil but this is controversial in its effectiveness and also needs an air gap on either side so I will not save much space. Another option is foil bubble insulation. Is their a thinner way that I can meet the required insulation amount?
Any thoughts and advise would be greatly appreciated.
NB: This conversion is out of necessity as I need to rent out my bedroom if I am to be able to pay the mortgage (thank you con-dems!). I am an amateur and will do as much of the work as possible myself. Please - no lectures about how I should work to regs - I an trying to do this but it is not possible with Celotex - hence the post!
Thanks,
Andy
Then floor boards
Thanks,
Andy
