Hi there, below is the spec for my floor base in my outbuilding that needs to be put in that BC have signed off.
Can someone convert it to English so when talking to builders I know what I'm talking about.
I know there is a base and insulation and dm but architect talk is above me
Ground Floor slab construction:
to be 75mm sand / cement screed on polythene, 500 gauge seperating layer over 75mm xtratherm hyfloor insulation with 25mm perimeter insulation of the same over 1200 gauge visqueen DPM or similar approved on 150mm C35 cast concrete slab reinforced with A252 mesh with min 35mm top cover over 200mm well compacted type 2 sub base.
Cheers all
Cheers all
