My first floor flat has Victorian floorboards in the hallway. 10 years ago I sealed the gaps between the boards with clear silicone. Over the years a few of the boards have warped and now split. I removed these boards to find a large water pipe running beneath them. This pipe serves the flat below and gets hot when their boiler/heating is on. I need to sort out this problem and replace the boards. This pipe runs a couple of inches away from the bottom of the boards.
It's clear that having sealed the gaps I have prevented the heat to escape enough to stop the boards from being damaged. But sealing the gaps is crucial because of cooking smells coming from below which by the time they reach my flat are headache inducing.
So, I don't want to remove the silicone and I can't relocate the pipe.
I've had an idea - to slide a length of pipe lagging/insulation onto this pipe to contain the heat and prevent it from rising onto my boards. What do you think?
