FloPlast PE-X Barrier Pipe 15mm x 25m White
I am considering using the above pipe to connect an external cold water mains tap to the existing 15mm copper installation. I would use a take off from the mains using a self cutting tap with check valve connection and make all the joints using standard brass connectors
I have read up about the FloPlast pipe and some people appear to have had trouble with it. As Screwfix are offering 25M for £16.99, it is attractive to me, but are there any known problems with this pipe and when using brass compression fittings. Should I use pipe inserts when connecting the pipe to brass fittings? Are there any other problems or tips that I should be aware of.
Thanks for any help, as these are difficult times and I would appreciate any advise as I am a learner in plumbing.
