Would like to replace steel underground pipe with 15mm plastic QUAL PE-X. Using supplied metal inserts each end, what fitting should be used to connect plastic QUAL to my existing 15mm coppers at Tank & house entry point.?
Standard brass compression type??
John2wires
John2wires
