Hi there have just had ceilings plastered and now painting finished.
Im left with no light fitted, and 1 month now with no lights down stairs.
Think i could do this one quiet easily with a bit of confirmation.
not sure the photos will help it looks like a spaghetti junction
I have
3 main cables.
1 from Switch,
1 from Wall light
1 from ring.
2 containing 3 core ( brown, blue,earth)
1 containing 4 core which gives me a grey wire?. (is it possible the 4 core was used in place of the 3 core and the grey has no use?)
The rose supplies a wall light which is activated by a double wall light switch at the door.
I have the same set up in my lounge but there is no 4 core wire that gives me a grey wire.
Also the lounge light is a circular fluorescent not sure if that makes any difference.
In the lounge the 3 browns are all attached to a free holding chocolate block.
3 Earth wires, attached to the Earth section of the permanent fixed, chocolate block, which has no wires exiting the other side.
2 Blues are in the N on the fixed block with wires exiting to the bulb
1 Blue in the Live fixed block with wires exiting to the power pack.
(I’m thinking for this bit you need to know which wires come from where to be able to separate and use the blue wires correctly.)
No wall light has been attached yet so I can confirm tomorrow, iof this is the 4 core or the 3.
can i ask which blue wire goes into the live section, would it be the main ring.
Regarding the grey wire if it has no use, would you suggest tape or block to keep it covered and out the way.
thank you for any help
I have
3 main cables.
1 from Switch,
1 from Wall light
1 from ring.
