    Dismiss Notice
flow thru elbow/rad valve
Discussion in 'Plumbing and Central Heating' started by hotncold, 13 Mar 2008.
  1. hotncold
    hotncold
    28 Feb 2005
    82
    Thanks Received:
    Country:
    I hope that this isn't a silly question but does water flow faster through an elbow compared to a fully open rad valve (assuming the other rad valve is also fully open?)
  2. Sponsored Links
  3. wiggikins
    wiggikins
    12 Sep 2007
    888
    Thanks Received:
    13
    Leeds
    Country:
    What size elbow?
  4. hotncold
    hotncold
    28 Feb 2005
    82
    Thanks Received:
    Country:
  5. Breesey
    Breesey
    11 Jan 2006
    860
    Thanks Received:
    28
    Sussex
    Country:
    Depends on the relationship between the size of the openings and the size of the tube delivering the fluid to the elbow or valve. Actual size is irrelevant.
    Assuming that flow velocity is equal as it enters either the elbow or the valve, velocity thru the elbow or valve will be dependant on its size and other factors like the internal surface smoothness etc. The right angle will drastically reduce the velocity also.
    The rad valve will, therefore, offer more resistance than an elbow so it could be safe to assume that flow thru an elbow will be faster than thru a rad valve (all other factors being equal).
    I am bored by the way :D
  6. hotncold
    hotncold
    28 Feb 2005
    82
    Thanks Received:
    Country:
    Breesey
    Thanks for your comments, I know it's boring but it will help you with my problem, I don't want to bore you with that as well.
    Just one more question, any guesses on flow reduction, 30%? :oops:
  7. Breesey
    Breesey
    11 Jan 2006
    860
    Thanks Received:
    28
    Sussex
    Country:
    I didn't mean you were boring me. My extended answer was a result of my being bored today!!
    To answer your question, not sure. Such comparitive data is available, but usually generic data is used for calculating such losses in systems.
  8. hotncold
    hotncold
    28 Feb 2005
    82
    Thanks Received:
    Country:
    well thanks anyway.
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
