Foam gun
30 Mar 2015
I probably use foam 3/4 times a year and end up buying a bottle. Is a foam gun worth it?
Also, for my garden room, I am likely to use this a few times over the next couple of months. Does it preserve for this duration?
If yes, can you please recommend one.
Thanks in advance.
Buy a pack of two foam guns off Amazon for £8 and see how that works out. I've tried looking after foam guns but they don't like sitting about when I bought B&Q metal guns for £10, now £15. Always keep foam in them. Foam cleaner works but you must fill with foam after cleaning through or they jam. Cheap guns are good for occasional use
so if I have a gun attached to a foam can and it sits in the shed for several months, when I then go to use it again, will it work fine or likely to be clogged up?
Well see the other threads. In my experience, "a few weeks" is OK, "a couple of years" is not.
The will still work because the liquid in the gun is sealed - in theory. when you operate the gun there is a rod that is inside the tube which seals the end. That's mine anyway.
I recommend getting one, I just used the standard cans and wished I have brought a gun years ago - every time struggling with controlling a can
which gun do you have?
