What foam gun?
5 Jan 2009
Hi all
Looking to get a decent foam gun that will last as I have door frames and other areas to fill.
I've viewed Screwfix/Toolstation and its mixed messages tbh.
Some plastic parts etc.
Anyone who regularly uses one recommend one?
Plus do i require the cleaning agent to keep it running smoothly?
Cheers.
I’d say any gun has the ability to either self destruct or get clogged, so I’d just buy the usual basic screwfix ones. Think my current screwfix/toolstation one’s been going a couple of years and the one from eurocell (I think) before that at the same price was similar.
I also never bother cleaning them. I just scrape the dried stuff off the nozzle and it carries on where it left off, days/weeks/months later. Never remove the foam can unless it’s empty, and replace straight away with a new one if removed.
As above. We use the disposable cans, rather than the gun as we use more low-ex adhesive stuff.
However all the window fitters we work with tell a similar story to the fellas above.
Just buy the £10 foam gun from B&Q.
For the control.
When can runs out I often blasted foam cleaner through then a new can of foam.
I always had foam in the gun and could leave for 3 months no problem.
I've never managed to clean gun out and store with no foam inside.
They clog.
Never sand or scrape the end as it buggers the seal. Foam keeps leaking.
Keep the end clean with foam cleaner when you are working.
After storing for months it will clog and die but done job
I wavered for years about getting one only being diy but a fiull house refurb prompted me to get a roughneck from Toolstation. The only mistake was not getting one years ago. I probably use <1/3 of the cans I did before, and that's foaming all sorts of bits I wouldn't have bothered with before as too much agg and it's quicker and far far cleaner.
As others say don't bother to clean. Just used mine yesterday after a couple of months gap: no issue at all.
I bought a cheap two gun set "Preciva" from amazon a few years ago expecting then not to last long based on other more expensive ones i had previously, and I've not had to use the second gun yet. The first has lasted even with a can siting on it unused for months.
Roughneck one. Treated just as 23vc mentions, worked for ages
I purchased the partially teflon/PTFE Roughneck one. I have been happy with it. From memory it was less than £30. The full PTFE version was just shy of £50. Mine has a PTFE needle and can be stripped down.
It was supplied with two long(ish) straws and two conical nozzles which go down to 2mm in diameter.
I often leave the foam can attached for up to 6 months. After each use, I spray the end with gun cleaner to prevent the end of the pin getting stuck.
During the summer, my foam gun spends much of the time on scaffolding, and, accordingly, gets wet. Mine is now nearly two years old.
My first foam gun was a freebie from BondIt with a purchase of 6 cans of foam. After using it once the nylon ball got stuck even though I flushed it with gun cleaner. The second was a £12 one from Amazon. It lasted a month and you wouldn't strip it down.
Edit - unlike the one recommended by @mrrustyy , mine has a flow knob to throttle the rate at which the foam comes out of the gun. After each use, I turn the knob to prevent accidental discharge.
It does - the brass thumbwheel behind the trigger, and that's what I do too
For years I've used cans but there is no control.
I was even purchasing in bulk and most would go off.
I had the cheapest Screwfix one plus the cartridge cleaner (probably some wd40 generic stuff).
What I don't u understand is that you keep the foam cartridge attached.
So you treat it like a standard paint spray can.
Turn upside down and get the excess out?
Cheers guys.
The liquid doesn't start to expand and harden until it has left the gun nozzle into the atmosphere. The liquid in the gun tube should, in theory, happily remain liquid for a long time, just like the liquid that is still in the can.
Once you remove the empty can from the gun, the liquid in the gun will start to expand and harden. So you need to clean it out ASAP with the cleaner cartridge, or immediately attach a new can of foam and fill the gun with unexpanded liquid.
This.
never take can off unless immediately replacing it, never worry about purging/cleaning, easy
Yeah. Unless you're not going to use if for a year or two.... which is the position I've found myself in. It does eventually gunge up, and at that point you might as well replace the gun.
