Folding squat rack fixing to single skin brick wall
gt2
14 Jul 2021
Hi Guys,
New to the forum but was looking for a bit of advice please? I want to fix a folding squat rack to my garage wall. It’s only single skin, 1970ish orange brick walls. I was looking at using 2 2x8 stringers with 6 m10 studs per stringer epoxy fixed to the wall. Will this be sufficient? I know the bolts will be fine, it’s the wall that concerns me. Any advice appreciated.
cheers
dave
2 Feb 2006
Staffordshire
Only you know the condition of the masonry. Can you not go floor to ceiling and borrow support (pull out resistance) from the ceiling timbers? Ply sheathing helps spread any load also.
gt2
14 Jul 2021
gt2, good evening.
OK I give up what is a --- not being cheeky but I cannot think what this is ---
Ah hello. I put a link in the original post but it has been removed. If you google wolverson compact folding squat rack it should get you there
gt2
14 Jul 2021
I’ll post a picture of the wall when I can but there are no ceiling timbers, just the roof rafters. I could maybe go right up into the rafters or maybe the wall plate for extra strength/pull out resistance?
2 Feb 2006
Staffordshire
It's more about spreading the load rather than concentrate it onto unreliable masonry fixings. However, you still need to take any flex out of the equation, otherwise your exercise regime will be inefficient.
I'd be thinking floor to rafter studs knitted together with ply and fixed to the masonry via angle brackets.
10 Oct 2017
I'd be using a free standing squat rack personally, what weight do you squat?.
gt2
14 Jul 2021
So maybe floor to ceiling 2 x 2 with one end directly connected to the rafter. How would you knit the studs together?
gt2
14 Jul 2021
It’s just the space issue, the idea of being able to fold it away is very appealing. I’m no particularly strong. If I was thinking long term goals the max that it would need to take would be 150kg
