FORD ESCORT R REG BLOWING NUMBER 3 FUSE
13 May 2009
Lincolnshire
my escort blows the number 3 fuse which is for the dash lights and O/S side lights and O/S tail light. any ideas i have check all wires i can see.
Cheers
Have you replaced any bulbs recently? if so this is where to start looking.
Wotan
Have any add-ons been fitted then removed by the previous owner, or the radio changed for a different one, possibly leaving some loose wiring waving in the breeze behind the dash?
no addons. the only things that are on that fuse are drivers side tail and side light dash light and audible warning buzzer that warns you you have left your lights on when you get out of the car. i have just taken both bulbs out and put a new fuse in and turned the side light on it blow the fuse straight away. I have taken the fuse box out and that looks fine. could it be the side light switch?
Do you have access to a multimeter?
You could check the circuit for a short to ground but you would need the fuse, bulbs, and buzzer out and the dash lights and switch disconnected. I know it's a faf but you are starting from a good point. If there is no short measuring from the circuit (feed to sidelight bulb would be easiest) to ground reconnect the light switch.
Recheck for a short with the switch in the sidelight position still with the fuse out. If you now read a short circuit to ground yes its probably your switch.
If however you still have no short to ground keep reconnecting the parts one by one, rechecking for shorts at each stage. Sooner or later you will connect the part causing the problem and Bobs your uncle.
If you dont have a meter you can follow the same procedure using a fuse and someone spotting it to tell you when it blows.
If you do have a short with everything out of circuit then it gets a bit trickier to find but at least you know where to start looking.
John
