ford puma.
1 Nov 2004
Hi All,
I have a 1.7 ford puma and it started to run really rough
today.
I plugged a computer in to it and it said 'missfire cylinder 2' and a code
'p0302' but i dont know what this means.
I have put new plugs in but still the same.
Could it be the coil block???
Please help,thanks-madsey. :(
It means what it says,you have a misfire on No.2 cylinder which could be caused by one of a few things.
1) check for a spark at No.2.
2) check compression.
3)If both the above check out o.k. then look to the fuel supply of this cylinder.
promblem solved.
It was the coil pack,£40 and fitted it myself.
Job Done !
