Foundation not level
29 May 2011
Yorkshire
I have been digging out the foudations over the past week before i lay the concrete i would like to be sure ive dug correctly.
I have noticed the foundation concrete will be a little more on one end than the other due to the slope at external ground level. Howevre The top of concrete will be level, Will this be ok or is it back to more digging?
You do want the bottom of your foundation trench to be level, however, there's nothing wrong with steps in your trench bottom.
Just level out stretches of the bottom and cut in steps, if needed.
There is three foundation, only one that's 5meter in length is the problem. It'll have around 200mm less concrete than the others at the bottom. The top surfaces will all be level.
Height deviations in the trench bottom are fairly common and not a problem.
Architects draw theirs with neat steps or level bottoms because they don't want the drawing to look naff and rarely encounter the muck and bullets of hands-on excavation work.
They do the same thing with drain runs all neat straight lines. Tickles me. :P
On many sites you can count yourself lucky if the top is level, never mind the bottom. In theory the bottom should be level. The text books will tell you that the building will slip. I wouldn't know if it's true as I'm long gone by then.
I think they had a special banana rule back in the 60`s given away by the Pitch Fibre drain manufacturers :wink:
Pitch fibre in the sixties? Luxury!! We were using the ultra modern-state-of-the-art Salt Glazed. Complete with user friendly gaskin it was a joy to use. :roll:
For 200mm I'd have put in a step - that's three courses or a course of block. But the point of a step is to save uneccesary digging and concrete - which is a bit late now innit.
Load of bunkum.
As stated a level bottom is irrelevant. Where does it say that the concrete can not be thicker in one part of a trench than in another?
Slippage - give me a break.
Marcus Vitruvius, the famous Roman architect who wrote De Architectura,
states it in his Christmas special edition 18BC page XV1111.
