I had a brief chat with a building inspector who advised me that the area where I live the normal foundation depth is 1 Meter. Is this the actual depth of concrete of just excavation depth? Thanks[/list]
You need to do a proper investigation. It's a monumental waste of time and money digging a 2m+ trench unless ground conditions require. My advice is do a trial dig and take a sample of clay from about a metre down. Have it tested for 'volume change potential'. The difference between low and high change can add 1.5m+ to your trench depth. Then you need to identify the tree more accurately. The difference between species and sub-species can also make 1.0 to 1.5m difference in trench depth. Then measure the distance from tree to foundation.Hi I am not sure if it's shrinkable clay? It is on a slight slope though! I am very worried about going that deep. I take it ply wood with mini acros will be ok to support the excavation ?
