Hi All,
My first post on this forum which has given me plenty of information so far!
My Plan;
I currently have a 10 year old 2 bed terrace house and wish to add a conservatory to the rear. The first issue i have is approx 300mm from my boundarys is 2 small round inspection chambers one each side (one for kitchen waste and one for bathroom and downstairs toilet). The only service my property and these have a slight angle pointing towards the middle of my garden. My proposed conservatory size is 2750mm x 4000mm (almost the whole width of house bar 300mm each side)
The problem i have is the run is going the same direction as i would need to add foundations. I am not sure if i can lintal over these pipes to bear the weight as these are so close to my boundary at the house and i cant dig under my niebours garden for the concrete side obvously.
Could i use steel lintals fixed onto my house brickwork bridging the drainage pipes with the other end on a concrete base/pillar as there is plenty of room further away from house.
I can add pictures tomorrow to help explain situation if need be.
Thank for any help provided.
Matt
My Plan;
Matt
