Free Kaspersky software
Cannot speak from recent personal experience but:
I suspect from reading many users comments that the Kaspersky offering better than Norton. Norton has had the reputation for being a resource hog and very likely the cause of slow system response.
There is a comparison here (take with a small pinch of salt as it looks like it may have been written by Kaspersky team)
http://www.ispinabox.co.za/downloads/KIS6vsNIS2007_Eng.pdf
You can't beat the Norton AV engine, but Kaspersky is very good.
Norton is a resource hog, and is expensive.
If the edition of Kaspersky being offered to you includes an anti-spyware component then that's A Good Thing.
Ditto anti-spam.
Whether you need a firewall or not depends on your OS and your Internet connection hardware.
If you're still of an impressionable age then you might need a parental control component.
I installed Kaspersky Internet Security (2007) on a pals machine, for the parental control element mainly. It works ok, certainly much better than Norton.
hi john, had a £50 package fitted to 3 laptops not so long ago, same
make, definitely slowed my comp down, on a scale, if norton slowed me by 5 seconds, Kaspersky costs me 2.1/2 seconds, actually, would like to get rid!!!
EDIT!!!just read the link john, exactly what i paid for, take it all banks will follow, at least i won't have to pay next year :roll:
probly will if i need the latest issue :roll:
Money MSN have changed the page that JohnD linked to. But if anyone wants to read the details they are here:
http://www.silicon.com/financialservices/0,3800010322,39254158,00.htm
Would be interesting to see the small print that Barclays customers will get in the new T & Cs.
Wonder if they will be covered for internet fraud if they do not use the Kaspersky or is this a 'cop-out' by Barclays.
dave
I installed Kaspersky on my pc running vista and had problems. Something about the software was affecting vista and made it seem as though unauthorised changes had been made - put it in limited use mode. Control panel was empty. Removed Kaspersky and installed AVG and it's fine (it's also free).
Having said that, I also used to use it on XP and found it faultless.
Vista.
It's a common fact that people just don't like change. Do you still have a black and white tv?
Way off mark, gcol.
Some of my living is derived from the fact that Vista is a backward step.
XP+SP3 is just marvellous - way better than anything before it. There are many machines for which I would be happy to recommend a change from Windows 98/Me to XP.
Whether or not to change OS is a business decision for me and many of my clients, and the only responsible advice I can give is to avoid Vista.
However, if you like useless but pretty sidebars/widgets, like to spend more on RAM than you'd need to with XP, like to have basic administrative tasks interrupted by security prompts, like to have familiar GUI features relocated and renamed for absolutely no benefit, and like finding that some of your existing software and hardware has become unusable, then the the way forward for you is clear:- get Vista.
__________________
Edit: corrected speeling mistaks.
Says who?
Is that because you don't understand how to use it?
However, if you like useless but pretty sidebars/widgets...
No I don't, I've got them turned off.
.... like to spend more on RAM than you'd need to with XP
Granted, but memory is cheap now.
Granted, but you can disable them - I have.
Granted.
Granted and that is annoying.
I'm conscious that I don't want to hijack JohnD's thread with a Vista v XP debate, but in Vista's defence:
The search facility in Vista is excellent and instant.
You can have files displayed in extra large icons - might sound trivial, but if you do a lot of drawings, this makes a massive difference seing what the drawing is before opening.
I play a lot of games and can take advantage of DX10 with Vista. I appreciate not everyone is into games though.
I find Vista much more stable than XP - used to have XP lock up or go into BSOD. Not so with Vista.
Says who?
1. Those end users who could cope with XP but who cannot cope with Vista.
2. Microsoft, for whom Vista is not making the revenue that they projected.
Do you need any more points of view than those of the end users and the manufacturer?
Don't be ridiculous.
You can also have them 'turned off' in XP.
More memory is never cheaper than less memory.
You can also have them 'disabled' in XP.
Granted.
So, a running total of Vista advantages is: nil.
...nil minus a huge number is a huge negative number.
Granted, but only at the cost of the indexing service constantly devouring resources that you might actually want to be using yourself.
There are third party add-ons that achieve the same thing in XP, but with less RAM.
I agree on both counts, but please refer to my previous post which was written in the context of business users.
It would be tantamount to criminal negligence if MS hadn't released some XP bug fixes in Vista, but have you tried XP SP3?
Says who?
No but I would like evidence to back up this fact.
I didn't think I was. Clearly, you think you're an expert.
Then why raise it as an issue?
So are you saying that XP is ok for business and Vista or XP is ok for home use?
Yes, I use it at work on my main pc. Vista on my work laptop and Vista at home.
...I would like evidence to back up this fact.
I'm more than happy for you to go off and get the evidence.
It doesn't matter what I think I am, it's all relative.
However, a better/clearer answer to your question would have been "No".
Because they're turned on in Vista by default, and because they are ridiculous trinkets.
Because they're turned on in Vista by default, and because they are ridiculous irritants.
I don't quite see why there's any confusion about what I've said. You were the one (or one of the ones) whose found some software that's compatible with XP but not with Vista.
I haven't mentioned home PCs. If you use a home PC, or a work PC, or laptop that you use only on the train, or plane, that's just for gaming, and you find Vista to be better for that, then please go ahead and enjoy it.
If you use a PC for anything remotely serious and/or to do with running a business, then I can't imagine why you'd want to waste your time disabling things that simply don't exist in XP, and wasting money by buying more memory, just to derive a platform that runs slower than the same machine with XP on it.
Am I right in thinking that you find your main PC to be reliable? If not, then why haven't you upgraded it to Vista?
This discussion started with your incorrect presumption that I don't like Vista because I don't like change. You can keep digging and trying to find more reasons why I don't like it, but I've already explained very plainly what the reasons are.
In short, it's pointless. Caveat games playing, supposedly.
And when something is pointless and at the same time incredibly expensive (measured in global terms), I infer that the money could have better spent on something more fruitful. Doing a bit more to Make Poverty History, perhaps. Or eliminate AIDS. Or.....I dunno. Anything. Just something that has some f***ing point.
