Free standing bath installation
6 Jan 2025
Does anyone on this forum have practical experience on installing a free standing bath? The best advice I have found leans hevily towards "don't do it" which is hardly helpful when I have £ooo's of cost already commited. I am particularly concerned with tiles under the bath and the connecting of the drainage to the bath which has a preinstalled outlet similar to a normal basin outlet. What is the sequence of doing the job given that testing for leaks is a need as the bathroom is directly above the lounge! It takes two strong men to lift the bath which is adding to the issues. The only plus point is that the joists are "engineered" and give about 15" clearance space between the floor and the ceiling below. Any advice will be greatly appreciated.
Just double check your sizes/heights, fit the trap to the bath and mark lwhere you need the waste pipe to be, exactly. Mark where you need the water pipes to exit the floor at the same time.
Then fit all pipework, coming up in the correct positions. You can plug and test them at that point, then finish the floor and fit the bath.
My daughter insisted on having one: horrendous thing which needed a long flexible connection for the waste as it sat on the floor all the way round so had to be held up to connect the waste.. Only good aspect was that it wasn't that heavy, but the flip side is that it moves around!! She has a totally independant freestanding tap. Ghastly in my eyes!!
I did one at me Ma's house (still there). It was a typical metal roll top fellla and I had the claw feet powder coated gold. The hot and cold upstands and wastes were done by the plumber.
