Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
if it (freezer) is fed from a supply backed up by an rcd if the rcd trips your frezzer will turn off.
It is quite common to put fridgee / freezer on own radial non rcd protected circuit
if the house is occupied all the time then having a freezer on same rcd as all the sockets isn't so bad as any trip is likely to get noticed pretty damn quick.
simerally if its running of a rcd that feeds everything in the garage or even just the freezer then if you visit the freezer freqently its not a problem.
the problem comes if you go away for long periods and want to leave stuff in the freezer.
I have my freezer on it's own B16 MCB radial circuit, feeding a 2.5.sq.mm cable to a 13amp Fuse-connection unit behind the freezer - a much better method
If you're going to have a dedicated freezer circuit wouldn't it be better to have an unswitched 13A socket. It can't get switched off accidently, but you can disconnect freezer quickly if you need to?
I thought that was only if the socket is likely to be used for outside stuff like lawnmowers? I've got a house that I let and everything is on 30mA rcd. The tenant once phoned to say the power was off. She was in the habit of moving the fridge to clean behind it and the cable had worn through and shorted out. This means the fridge case was live until the rcd tripped so my opinion is fridge goes on rcd. Perhaps a 'one-off' not likely to happen again, and she should have switched off before moving fridge, but it did happen.
