Freezing cold attic radiator.
3 Dec 2007
Hi guys.
Had some work done to our old boiler and the whole heating system was drained out and re-filled.
Now all our radiators are hot except for the one in the attic. This is also where the hot water cylinder and pump are with the little water tank above.
I have done some reading on here and have tried to bleed it. Water comes out of it OK. Radiator is still cold as are both the pipes that supply it on either side.
Is there anything i can do to get this radiator hot again...
balance the system and make sure you do not have a "manual" bypass if you have zone valves and NO bypass with a 3-port
How will i know about a bypass??
Someone has also suggested turning off all my other radiators to push any airlock out of the attic one and then to 'balance'. Would that be something to do.
Turn boiler off. let sysem cool down. close all rads. select heating only. feel flow pipe from boiler. if it gets warm, follow the heat and you should find the bypass
