French Door
27 Jan 2007
Hampshire
Dear All
I am intending on fitting UPVC French Doors in place of an existing window. The width of the window is OK however the underside of the lintel is 2.3m above where I want the sill / cill of the door to sit. As the frame is about 2.05m in height, there is going to be a 0.25m gap between the top of the frame and the underside of the lintel. The outer leaf is a brick wall with a concrete lintel.
Has anyone got any ideas on filling the gap?
My current thought is to put UPVC flashing with insulation behind it.
Thanks in advance for any advice.
GuyC
5 Jan 2003
Essex
Do you mean 0.25m which is 250mm or is it 25mm :?:
2 Feb 2006
Staffordshire
if you haven't already made the doors, why don't you ask the manufacturers to include a slim top light (fixed) to make up the difference?
