it's called "trace heating"
http://www.traceheatinguk.co.uk/[/QUOTE]
Thats the one......was one the tip of my tongue!
Is DIY fit of that possible for a condensate pipe?
modified my condensate pipe to 32mm but if it still freezes this winter i'll need to revisit the problem.
Loads of calls last Winter for frozen condense pipes,and easy work.I don't know if this has been mentioned b4 but there is a heater that can be fitted to external pipe work that comes on when outside temps fall to near freezing.It takes the form of a long cable/heat element that is fitted underneath the condense pipe and wired to a perm live off the boiler.
tickly t said:Maybe something along the lines of an automatic flushing cistern? The penalty would be the space taken up by the store, which would need to be indoors, and probably close to the boiler
Trace heating is all very well but if it is cold enough the stack will freeze too.
Whatever happened to the development of the idea of the condensate being released through the flue as a mist?
That one seems to have gone quiet though it seemed like a good idea.
They're is now a new line of though from the worlds top scientists that releasing the condensate into the waste system could be more damaging to the environment than releasing into the atmosphere.
Corgigrouch";p="1731724 said:I can't help feeling that the worlds top scientists need a greater problem to think about...
You can take it from me that saving the world that we live in is pretty high up on scientists list of things to concentrate on!
P.S. I have a formal qualification in building science so I do know what I'm talking about.
