Is it ok to use pvc tubing
Its a McCulloch PM310 (1986 model). The line might have swollen and as you implied 3x6 mm tube might be better. The carb inlet tube is just over 4mm and the tank hole is just over 5.5 mm.Just for my interest, what saw is it?
John
yes its old but good and there are no grommets on the tank,its just a squeeze fit. I ve found a supplier but dont like their charges. cheers!Sure, thats an old 'un....horizontal cylinder and that......any fuel pipe needs to be a good fit through any grommets where the fuel tank is concerned. Any internal diameter will do as its a small capacity saw.
John
