A friend has an old victorian villa, his wiring is really old (rubber) I'm sure he has a fuse on the live and the neutral incoming terminals, when did this practice stop?
Not sure when it changed, before my time! Its amazing how technology has advanced in the last 30 years with what we use nowadays.
Be careful with these when removing the fuse (well it should be sealed so you shouldnt be able to!), i was at one the other day and pulled the fuses - one of the ceramic pull outs was broken down the side where your fingers are meant to grip it so i could have easily touched the fuse whilst it was live.
Rubber glove time i think
Oh and tell your friend to get a rewire if he has rubber cable still
If you ask your supplier if they currently comply with ESQCR re fused neutrals you probably won't get a reply - I tried with two suppliers and neither replied.
Bas, I only enquired because I was intrigued by the rider in the 17th re ESQCR. It could be a big problem because I doubt if any DNO can ever be 100% certain that they have replaced all neutral fuses with links.
