Hi Guys,
Back again with another question - I'm hoping someone will be able to help.
I've got the Visonic PowerMax Complete alarm, it doesn't come with the adaptor has to be hard wired. I am planning to break into an existing circuit (a junction box is only 6 feet away from where I want to install the alarm). I plan to run a cable from junction box which I will feed into a Fused Spur, from fused spur I will run a small cable into the alarm.
My question is am I ok to do it this way, I will use a fused spur that has no on/off switch, also can you advice what amp fuse is required for fused spur.
many thanks,
VK
many thanks,
VK
