I'm fitting a new kitchen but am using the existing double oven and electric hob for now as they both work fine and the wife and I haven't decided if we'll be having the same setup when we upgrade. We will probably go for induction hob and either double oven again or single oven and built in combi microwave.
Existing wiring is 6mm cable from 32A mcb to ccu which has two 4mm cables running to oven and hob.
If two 6mm cables run from two separate 32A mcb to two separate ccu again with 6mm cable for both, will that be ok for any future oven / hob setup we opt for?
Any advice appreciated
