    Dismiss Notice
Gable ladder sizes
Discussion in 'Roofing and Guttering' started by an203888, 21 May 2020.
  1. an203888
    an203888
    4 Jan 2014
    129
    Thanks Received:
    2
    Norfolk
    Country:
    I'm going to use pvc 150mm Barge board. Can I use 4x2 timber for the ladders and end rafter? The overhang will be 150mm so don't see an issue with strength.
  2. an203888
    an203888
    4 Jan 2014
    129
    Thanks Received:
    2
    Norfolk
    Country:
    Anyone able to offer advice?! Bump!
  3. catlad
    catlad
    29 Jul 2011
    3,929
    Thanks Received:
    529
    Lancashire
    Country:
    I can't see why not.
    • Like Like x 1
  4. noseall
    noseall
    2 Feb 2006
    37,672
    Thanks Received:
    2,419
    Staffordshire
    Country:
    Yes, its how we do ours.
    Even if say we are using 6 by for the main rafters, we always bring the ladders through with 4". It means you can brick up to the 4" noggs then thicken down with a batten this covering any bigger joints and it provides the ideal depth for hollow soffit and a 150mm cap-it fascia.
    Always fix your end rafter before bricking under the noggs.(y)
  5. Sponsored Links
  6. an203888
    an203888
    4 Jan 2014
    129
    Thanks Received:
    2
    Norfolk
    Country:
    Done cheers :)
    • Like Like x 1
  7. 23vc
    23vc
    17 Apr 2015
    1,770
    Thanks Received:
    243
    Warwickshire
    Country:
    why? Doesn’t that make the brickwork a bit fiddlier
  8. noseall
    noseall
    2 Feb 2006
    37,672
    Thanks Received:
    2,419
    Staffordshire
    Country:
    Yes it does. But it also straightens up the noggs which is slightly .more importanterer
    • Thanks Thanks x 1
  9. an203888
    an203888
    4 Jan 2014
    129
    Thanks Received:
    2
    Norfolk
    Country:
    I'm finding my end rafter is being straightened by my noggins!! Can't find a straight bit of wood anywhere!!
Loading...
Share This Page
