Galaxy Dimension GD-48, tag won’t set block
4 Mar 2025
Belgium
Hello everyone,
So I’ve got a Galaxy Dimension GD-48 and I’ve programmed 2 blocks. One is for ‘away’ and the other is for ‘night’.
I’ve added tags to the users.
When I use the tag to set the away setting it nicely sets and I can unset also with the tag.
When I use the tag to set the night setting it just gives one short beep, but does not set.
I can set the night block using the code which belongs to the user with the tag and then unset using the tag again.
When I set another card function 42.1.8 to the tag (eg. 21 system) it works fine so the tag and user are properly programmed.
The user and block also have access to the same block (night), so no restrictions there.
Hope there are any GD specialists the who can help me out.
Thanks in
advance!!
Do you mean part and not night or are you talking about setting different groups?
With blocks I mean groups.
Sorry, I'm dutch ;)
So the group I call night only contains the magnet contacts on the windows for during the night time.
I can set this group with the code, but not with the tag.
Ok, so I did some more testing.
When I give the user accès to group 1 and 2 (day and night) it does work.
It looks like group 2 is missing something that allows me to set using the tag.
Really hope someone has the golden tip because this is killing me
Do you have an Ethernet module ? If so, I can connect remotely and check your config. PM me details.
