    Dismiss Notice
Galaxy Flex and Touchcentre
Discussion in 'Alarms, CCTV & Telephones' started by NeilCNF, 14 May 2020.
  1. NeilCNF
    NeilCNF
    14 May 2020
    Thanks Received:
    Country:
    Good evening
    I am after some advice if I may please.
    I have a Galaxy Flex100 panel and we want to link up TWO Galaxy Touch Centres to it. I believe on a standard panel we can only use one Touch Centre. Is there any expansion modules or similar we can use so that both Touch Centres can be used on the system?
    Any advice greatly appreciated.
    Many thanks
    Neil Fearnley
  2. Sponsored Links
  3. scott1980
    scott1980
    3 Mar 2006
    496
    Thanks Received:
    93
    Manchester
    Country:
    The Flex panels will only support one Touchcentre, this can't be expanded in any way. You can have 1 Touchcentre per data line on the larger Dimension range of Galaxy panels but this would require you to change the panel to at least a Dimension 96.
  4. GalaxyGuy
    GalaxyGuy
    7 Jan 2014
    711
    Thanks Received:
    120
    Fife
    Country:
    Sorry, the Flex will only support one TC. The Dimension 96 and 264 support 2 and the Dimension 520 supports 4. The Flex will only support the keypad mode on the second one. You may be better off using an in-wall mounted tablet and running a virtualkeypad on it.
Loading...
Share This Page
