Galaxy flex entry or exit zone
1 Oct 2019
Hi, I have a magnet on the door zone1 set to final. Should the pir in the hall, zone2, overlooking the the door and keypad be set set to Exit or Entry?
Thanks in advance.
Jeramy
The manual indicates you should use "Exit". "Entry" appears to be the recommended setting in combination with a "Push Set" zone, but the text is a bit ambiguous.
Will i get false alarms if the final door zone and the hall zone become open at the same time?
Do you have a final door zone and if yes whats the pir facing set to?
Yes, use exit - unless you use part set and the same PIR is first to trigger in the morning. If that's the case use part entry.
