Hi
i bought a cqr sounder which i mistakenly bought the sounder version only instead of speaker/sounder so that i could hear the entry exit tones outside the door when setting. . however that worked fine on intruder activation and sounded.
i now have the speaker/sounder version however the additional 2 speaker terminals at the top say audio in and audio in.
can someone confirm do i still wire red to +12 to one audio input and the other to output as it says 'unpowered' speaker on the manual and then still have the output zone programmed as e/e
also does this speaker have to be wired back to OP3 on the flex panel or can i use op3 on the c072 rio which is where i set connected the original sounder model to.
thanks in advance
thanks in advance
