Galley Kitchen - advice?
6 Sep 2020
Hi All,
Hope this is the right forum!
Am just looking for a bit guidance.
Cut a long story short we would like to fit our own utility room, father in law will plumb in the sink/tap
and separate company will cut the stone worktop.
It is a galley utility going from wall to wall.
It will contain Larder cabinet, sink base with wall cabinet above and then a "DIY" cabinet made of end panels and doors
for the freestanding stacked washer/dryer.
My question is the larder will be side onto a wall (crude plan attached).
At number 4 i think i need to leave a gap between the wall and the unit so the door will open properly - is that right?
My question is should i use a timber filler and then a bit of the plinth to finish it or should i just make things
easy and buy an end panel?
I'm just asking cos the end panels are like £140 where a small piece of timber and offcut of plinth is significantly cheaper.
Just wondering what others would do when its DIY?
Thanks in advance Lou
You only need a panel width (18mm) on the left of tall unit you could use the off cut from full height end panel if you are using one on the right of the tall unit or strip of 18mm mdf with colour match tape trim on top .
Or if on a budget simply paint the mdf trim to match the wall.
