Gap under shower door cubical, driving me insane
23 May 2006
Southampton
http://www.diynot.com/network/tryitandsee/albums/
I have installed this B&Q shower cubical complete with tray and platform etc. but water seems to get out from a gap between frame and underside of pivot door. There is a feeble clear plastic 'splash' trim that runs the full width of the top and bottom of the door, but there is still a gap. The door is pivoted top and bottom with single pins and doesn't look like it can be adjusted in any way.
Has any one come across this problem, or managed to resolve it.
I appreciate 'you only get what you pay for........' . As the sheds are quiet at the moment, I'm thinking of asking them to come and take the thing out and replace it with one that does not leak. I've been fannying about with it for hours. I've never tried to do this before, but as it's obviously not fit for purpose, they can bloody well compensate me for the time and effort fitting it :evil: ...........good, got that rant off my chest :)
Help appreciated.
if your base is not 100% level it may be that
some of the less expensive cubicle sets do not have as much tolerence or adjustment features of a pricier model.
i fitted 2 good sets last week, made by flair doddle and quick
seen me 5/6 hours on some of them and they are dung.
basically when it comes to shower screens , the more you spend the less time you are farting about , i know some of them are a nightmare or worse
:D
I emailed B&Q with complaint as I got nowhere in the store. £25 in vouchers on there way. No way compensates the time and effort fiddling with the pivot door, but worth the email.
If you have to get the cheaper shower cubicles as I did, don't buy the Barcelona pivot door cubicle, get the Barcelona bi-folding door one instead, better design and water tight at bottom of door.
Ya really only gets what ya pays for! :wink:
unless it says explicitly in the instructions that this model will not let water through the door, you will not get very far under the not fit for purpose routine; it is after all a budget shower
had the exact same problem three weeks ago with the very same cubicle, absolute nightmare of a job
worst thing was it was a job for a friend !!!!
Solution to the problem - use white plastic L(or preferably Z shape angle (can be made by gluing two 10-15mm L's) and adhere to bottom of door cut around hinge as appropriate. Silicon sealant will make it look beautiful and do the business.
Have done it on couple of installations and looks and works fine
