I wonder if anyone can help (sure you can).
I have fitted kitchen work surface and tiled all the walls.
Thing is there is a gap between the tiles and the work surface as you would expect. In some areas it is larger than others and sealant just dissapears down the back of the work surface. Is there an adhesive moulding I could use to cover gap or a technique to make sure the sealant doesnt disapear down the back of the work surface.
