Hi Chaps, right here goes I'm pretty competent at attempting anything DIY related and love to do things myself however i do work in IT so bear with me! I am going to convert my garage into a summer house. Currently it sits at the end of the garden and collects junk. My plan is to (and this is where i will seek professional help) brick up the door and have bi-fold doors put into the side, which will open up onto my garden... every other job I'm going to try to do myself.
However before i even start to think that far ahead I want to board the top of my garage for storage, I will eventually put a loft hatch in. My first aim is to clear the floor space. To do that I need to board the roof area out to use as storage. I was thinking of cutting 18mm OSB 3 boards to sit on top of the rafters (see pic) for now. Then come back and insulate between the rafters (from below) and then start the plasterboard etc. my question is can anyone recommend a starting place. I'm not sure how to damproof the boarding if it needs it at this stage? I'm conscious that the top area will be cold and the bottom, once finished, (hopefully) warm.
The garage does have electrics and a v shaped loft area which i currently use to throw any old junk up there. The garage was built 4 years ago and is a double with my neighbour.
Thanks for any advice you can give you guys were awesome in helping me last time, this is the first step of many which I will be seeking your help with...
Thanks, Aaron
Moderator's note
Please see //www.diynot.com/diy/
Thanks, Aaron
Moderator's note
