Garage door and insulation
9 Feb 2010
Worcestershire
HI,
I have an uninsulated garage door...ie bare metal.
Do you think it would be possible to use the foam stuff they use for filling in around holes in brickwork to give it a coating which would provide insulation?
Regards Al
Trying to coat something with canned foam is an exercise in futility and waste (I speak from experience). The only viable way would be to build formwork to contain the stuff where you want it to go.
Sheets of 25mm polystyrene bonded in place is probably the most feasible option. That said, if you are planning to heat the space, you will get condensation (and ice in freezing conditions) behind it.
You are obviously wanting to use it for something other than a garage - tell us more, there are better options.
Its simply for the garage door. Last year it got very cold so I used cardboard to try to keep the cold out. As you say I don't think the foam idea is feasible. I'll have a look at using metal backed polystyrene foam slabs instead. Thanks for your help
Even if you succeed, all you will achieve is to slightly slow down the process of reaching equilibrium with the external temperature. Is it worth the effort?
