Garage door weather bar
14 Mar 2006
Essex coast
Looking for a stockist of weather bar to fit to my garage doors, need to be about 1200mm long but all my local timber merchants only keep 1 metre lengths for domestic house doors.NW Kent.
A weather bar would need to overhang and completely cover any of the garage slab 'toe' or else it will be useless.
Depending on the driveway although not impossible, I did a drainage for my mum's garage chopping out a channel 100mm under the door and backfill with pea shingles like a soakaway
It could be easier for you to run up your own weather bar with a router...so long as it has a drip groove, the profile doesn't matter much.
John :)
assuming they are outward opening
before you attach anything to the front off the doors check how it will effect the door opening as in fully open the door then imagine you have 21mm then a 43mm bit off wood on the face off the door and see how it will efect the doors opening
angeling the ends can often help the opening width
