garage roof
8 Nov 2004
my garage roof is leaking in places and i think it needs replacing. is this a job i could do myself, i am quite good at diy but have never done a roof before, its a flat roof . also what do you do about things like fuseboards, boiler etc to rpotect them rain whilst you are doing the jiob
thanks
Bill
A garageroof normally only takesaday to get watertight even with replacing any rotten decking, so no need to worry about your fuse board etc.
I wouldnt reccommend doing this one yourself, imo you need aprofessional roofer in, get a fewquotesfor a3 layer felt system with mineral finish, done properly will last you 30 years, we guarantee ours for 25 years normally.
Use EPDM and its very easy for DIY
There are also some self adhesive (cold bond) bitumen felts on the market now which don't require hot works
If you don't think that you will finish in a day, then just get a large tarpaulin or sheet of thick polythene as a temporary cover
Check the boards first to see if they need replacing too (ply is better than OSB), and if the fall was not very good, fix some new furring strips
