I have had a look around to see if there is a similar solution but as with many of the topics on here, each problem can have it's different solution.
As you can see from this image, I have a filler loop for the boiler and (on advice from another plumber) I occasionally disconnect the top connection on the loop to attach a hose fitting for my pressure washer however it is at the back of my garage and not too convenient to have to muck around with the loop when I want to top up the pressure on my boiler occasionally. Consequently I'd like to run a pipe to the front of garage, utilising this point in the system somehow.
I think I could connect another pipe to the top valve shown with a T and another value to connect the loop to but I am not convinced this is the best solution.
Ideally I would shut off the water and splice in a new T to run the new pipe from before the existing value but I can't seem to locate a stopcock for the house to switch off the supply to allow me to do this and don't think it's right (or legal?) to turn off the supply from the street.
Hope someone can help but if you need any more info (or for me to explain it better) and more pics, let me know.
Chris
Chris
