- Joined
- 12 May 2025
- Messages
- 20
- Reaction score
- 0
- Country
Hi all,
I'm looking for some advice regarding converting an existing garden room. My house has an timber garden room which has mainly been used for storage since we moved in. Now I'm looking to make it more of a room and something that can be used all year round.
My first job is to insulate the base and install some flooring.
For reference it looks like it is currently sat on a concrete base and below this is a solid membrane.
I'm looking to build a frame inside around the existing floor with timbers across at 450, fill the gaps with 50 or 75mm PIR and then lay some OSB on top followed by some flooring (likely vinyl).
I have a handful or questions.
1. When I build the timber frame inside do a leave a small gap between the existing wall or can I fix to the existing wall (timbers are 40mm) for shrinkage and expansion?
2. Do I have to do the same with the OSB or can this butt up to the wall?
3. Do I have to install another memberane under the new frame and existing floor?
4. I currently have a double beveled circle saw, a hand circular saw, hand saw, impact driver, multiple spirit levels, laser level and hand tools is there anything else I will need?
I have attached a rough floor size and a picture of the room to give anyone a better idea of size and it's make up.
Many thanks
Craig
Many thanks
Craig
