    Dismiss Notice
Garden tap attached to heating pipe?
Discussion in 'Plumbing and Central Heating' started by medway, 27 Apr 2010.
  1. medway
    medway
    27 Apr 2010
    26
    Thanks Received:
    Kent
    Country:
    Hi there,
    This may sound thick but I have to ask.
    Basically I am about to fit a garden tap kit and the best pipe for me to use to attach cut off tap into would be the pipe going to the radiator in the bathroom on the outside wall.
    Will this work if I do this and what issues would arise if I did?
  2. Sponsored Links
  3. :eek: seriously, this a wind up.
  4. medway
    medway
    27 Apr 2010
    26
    Thanks Received:
    Kent
    Country:
    lol no.
    What harm would it do?? As you can tell im not a plumber :(
  5. 45yearsagasman
    45yearsagasman
    14 Mar 2010
    6,089
    Thanks Received:
    1,092
    Norfolk
    Country:
    Don't even think about it.Tee into your cold main supply and not the CH pipework!! This must be a wind up.
  6. sime10
    sime10
    19 Oct 2006
    792
    Thanks Received:
    6
    Cardiff
    Country:
    :LOL: :LOL: make sure you put plenty of inhibitor onto your garden too to keep the rust off the grass
  7. medway
    medway
    27 Apr 2010
    26
    Thanks Received:
    Kent
    Country:
    its only water going into the radiator and it will be cold in the summer when i will be using the hose so didn't think there would be a problem :(
    The only other option is using the pipe that goes into the toilet, would there be any problems with that?
  8. Astartes
    Astartes
    29 May 2009
    66
    Thanks Received:
    2
    Fife
    Country:
    If your loo pipe is mains fed go for it. Someone will be along soon to tell you how to fit according to regs. Under no circumstances use the rad pipe.
  9. seco services
    seco services
    3 Dec 2007
    15,701
    Thanks Received:
    1,260
    Essex
    Country:
    well he's already said it's one of them garden tap kits.
    what else can i say.
    restricted bore hose.
    no internal check valve.
    clamp for joining to mains feed. :rolleyes:
    • Thanks Thanks x 1
  10. Sponsored Links
  11. seriously.id get someone in to do this.as you sound as though youv no concept on what is involved.at least it will be piece of mind,when done properly.eg service valve, check valve inside.and not them crappy kits you get from the sheds.
  12. medway
    medway
    27 Apr 2010
    26
    Thanks Received:
    Kent
    Country:
    ok i guess ill have to go with toilet pipe, but just out of interest why shouldn't I use the radiator pipe?
  13. medway
    medway
    27 Apr 2010
    26
    Thanks Received:
    Kent
    Country:
    how much does it normally cost to get someone into do this kind of thing?
  14. seco services
    seco services
    3 Dec 2007
    15,701
    Thanks Received:
    1,260
    Essex
    Country:
    to many reasons to list. ;)
  15. ajstoneservices
    ajstoneservices
    1 Aug 2008
    6,360
    Thanks Received:
    1,092
    Norfolk
    Country:
    Medway,
    Cheered me up thanks :LOL:
  16. twgas
    twgas
    26 Oct 2007
    4,900
    Thanks Received:
    426
    Kent
    Country:
    You guys are obviously not familiar with the Medway towns'folk :eek: :LOL: ;)
  17. seco services
    seco services
    3 Dec 2007
    15,701
    Thanks Received:
    1,260
    Essex
    Country:
    i knew they where all strange on that side of the water.:cool:
Loading...
Share This Page
