I've got a garden tap that has poor flow; it's not drastically poor but not as heavy as it should be. I removed the hose from the tap because i thought it may be the tap itself that may be restricted but the flow from the hose is identically poor. The other end of the hose goes inside the house via the brickwork and uses the 'cut into the pipe' type connections on the cold water feed just off the rising main.
Any ideas why the flow is poor?
I need to increase the flow to effectively use a pressure washer.
thanks for any help.
