I've just had a electric hob replaced by a gas hob. The electric hob had its own circuit but is now switched off from the fuse box. I just had a couple of questions.
1. the gas hob came with a plug for the ignition, the gas engineer just plugged it into a socket inside the cupboard. Does the electric regs require a switch to be above the worktop (in easy access) for a gas hob? or only required for elec hob.
2.my electric oven wiring is also going into the cupboard and there is no switch above the worktop to switch if on/off. I was wondering, could I wire my oven into the wiring which was being used for the elec hob? that way there will be a switch above the worktop to switch it on/off in an emergency or is that not required by regulations for elec ovens?
Thanks,
Thanks,
