came across this strange set up of the gas pipe. (see photos,) the gas pipe enters the property via 15 mm copper pipe then goes through this strange configuration of pipe work, then it connects to a lead pipe and goes off up through the ceiling , before this there is also a tee pipe off the lead pipe which terminates and the end is just crimped over!
Also the copper pipe you can see with the bonding cable attached that heads under the floor has been disconnected.
The gas pipework to the boiler at the back of the property is connected in copper pipe.
What are your thoughts and should it be condemned?
View media item 11683 View media item 11684 View media item 11685 View media item 11686 View media item 11687 View media item 11688 View media item 11689 View media item 11690
