Gas Pipe form Propane Bottles to Hob
11 Apr 2007
Aberdeen
Hi
We are having a gas hob installed and I was wondering which supply pipe to purchase ?
I will not be making my own connection, I am just looking to purchase the necessary materials.
As I understand it there will be a couple of propane gas bottles outside the house with a pipe running from the bottles under the ground, through a plastic sleeve through the wall ( still underground ) coming out under the kitchen units and then up to the hob.
The hob will be a 5 burner unit. The pipe will run for no more than 10 metres with no connections in it.
Am I correct in saying that plastic coated copper pipe ( which comes in a coil ) will be right for the job ?
Could any one tell me how to calculate the ID required to ensure sufficient gas pressure at each of the hob burners ?
Cheers
Probably best to ask the person who's going to install the hob and make the final connections. ;)
gas4you said:
Get wif it you guys!!
I cannot be the only happen' young dood here
I am getting a hoody on the morrow
Yay I am so home with the downies
GRANDAD :eek: You're as bad as the sparky i worked with last week who asked if I was alright with his radio on virgin or did I want him to change it to Radio 2 :eek:
I told him that the only station I listen to is Radio 1 :rolleyes:
Radio 2 I ask you, thought I was with it and strutting my funky stuff :LOL:
