Can be sealed under the floor but cannot use compression fitting to do so.
Therefore must be soldered joint.Job for RGI as to do this correctly the gas meter should be removed and reconnected and installation tested afterwards.
What they are saying is the silver bit will unscrew from the (iron) pipe and it will need to be replaced by a screw cap or screw plug that will go onto or into the exposed fitting. You may be lucky if it finishes below the floor board level - otherwise the RGI have to go below to the next joint.
